DST-2:1103#4 upload fail
[Warning] Destination error: ${https://sqlbackupandftp.com/kb?%3A1103%234|#[DST-2:1103#4]} Failed to upload " > Failure; Failure.
I make the backup in two different FTP but in the second it gives me the following error when trying to upload the backup to our S3 bucket DST-2:1103#4
This start happend 1 moth ago
Hi Miguel_Anez,
For the correct work with FTP, we use Rebex libraries. Could you please try to install the following test Rebex client Dropbox - RebexFtpClient.zip - Simplify your life and check if you are able to connect and download a file to your FTP via RebexFtpClient?
