Disable column-statustics by default
Is it possible to set the “Generate statisitics histograms” drop-down value in the mjbox file pripr to importing it or changing the default to to columon-statitics = 0?
The databases im backing up doesnt have the table and im getting an error each time the backups run, I generate templated mjobx files and import them via a script and with the number of databases manually changing the drop-down to isn’t really a feasible solution.
Hi Hotan_Haghighatgoo,
Sure, you can find that option at the “MySQL Backup Option” window.
