Destination error
I keep getting error but only on one of my destination drives. I don’t even have verify turned on. Any ideas? Thx
6:46:34 PM : ERROR: Destination error: [DST-1:1108#2] Destination file “master201707271845.zip” “0” is not equal to local one’s “master201707271845.zip” “478650”.
It seems the issue is related to your environment. We are going to release a new version of SQLBackupAndFTP application with additional file validation after copy it on a folder destination.
Regards,
Alexey
I downloaded and installed the newest version 2 days ago for a trial and I’m having the same thing happen. I also don’t have any sort of verification option turned on. It’s happened both days that it’s run. I checked on the destination FTP server and the file is there and seems to be fine:
Here’s the error message in question along with a few of the log entries before it:
11/16/2017 10:15 PM Uploading the local file “TA201711162215.zip” into a remote file “TA201711162215.zip” on the remote folder “/Backup/TA”
11/16/2017 10:15 PM Uploaded 100 % (average speed = 261.8 KB/s)
11/16/2017 10:15 PM Verifying remote file “TA201711162215.zip” with local one “TA201711162215.zip”
11/16/2017 10:15 PM Destination error: [DST-2:1108#2] Destination file “TA201711162215.zip” “0” is not equal to local one’s “TA201711162215.zip” “1101860”.
What can I do to resolve this? We’d like to use this product but not if I’m going to be emailed every day with a failure, when really, it’s actually succeeded.
Thanks.
Does it use “FTPS” protocol for the FTP server? Please, try to upload a backup file on the FTP destination with “Pause before upload close” option. You can find this option on “More FTP Settings” window.
Regards,
Alexey
Change the compression method from .zip to zip(7-zip engine) or uncheck the compression. It will work this way.
Hello Konstantinos_Lalaoun,
Thank you for the information you shared.
