Destination error DST-1:1001#102
I try to connect to a network drive and I get the error.
23/06/2023 8:42:09 πμ [Error] Destination error: ${https://sqlbackupandftp.com/kb?id=DST-1%3A1001%23102|#[DST-1:1001#102]} Failed to open “\PCIT01\SQL Databases Backup” destination connection. > ${https://sqlbackupandftp.com/kb?id=DST-1%3A1001%23103|#[DST-1:1001#103]} Failed to open “\PCIT01\SQL Databases Backup” destination connection. > The specified network password is not correct
As you can see I point the network drive correctly like \PCIT01\SQL Databases Backup
I have try also like \192.20.10.180\SQL Databases Backup and the error insist.
The point is when I press the test button it says
Local/Network Folder/NAS Settings
Connection successful.
OK
Where is the problem?
Hello Makis_Best,
To resolve the issue, please ensure that you have specified the path starting with “\” and have provided the user name with the domain.
If you have any additional questions, please feel free to ask.
Thank you, and we apologize for any inconvenience caused.
I am sure that both paths are like \192.20.10.180\SQL Databases Backup or \PCIT01\SQL Databases Backup. Same error.
Hello Makis_Best,
Apologies for the inconvenience caused. It seems that one slash got lost. Please make sure to specify the path starting from two slashes like this: \\192.20.10.180\SQL.
SQLBackupAndFTP
If you have any further questions, feel free to reach out to us.
Thank you for your understanding.
