I want to restore zip file to sql and error message is [Error] Failed to restore “1_UTAS_SAVUNMA_AS_2013” database. Failed to extract files from archive. > Could not find a local header where one was expected in the zip file.
can you help me?
Hi Ali_Vekil,
Could you please tell us more details about the settings you use? Are you going to restore your backup from your log or via a Restore job?
Please send us a screenshot of the issue and a full text of the error message you get.
Hello Francisco,
Could you please try opening the archives manually using a standard archive program such as WinRAR, 7-Zip, or a similar tool?
Let me know the result.
The ZIP file is not available on the computer, even though the ‘Keep files local’ option is enabled.
Hello Francisco,
Thank you for your reply.
From your screenshot, I can see that you’re storing backups on OneDrive. Could you please try downloading one of the backup files and manually opening the archive using a standard tool such as WinRAR, 7-Zip, or a similar archive manager?
Let me know if you’re able to extract the contents successfully or if any errors occur during the process.
