Connection to MS SQL Server
I am using MS SQL Server without password. Unfortunately when I fill user name an password like this I get the following error.
Would somebody be so kind to give me some advice?
Thanks :slight_smile:
Martin
Hello Martin,
Sorry, but there is no way to do it, that is how SQLBackupAndFTP works.
Please use a username and password to set a connection.
many thanks for your reply! Unorderly I cannot find how to set up a password. Could you give me a hint?
I really appreciate you support.
Best,
Martin
Dear Martin,
Could you please contact your system administrator for more details? Also, you can find an instruction on how to do it on the web, for example at Change or reset your Windows password - Microsoft Support.
Ah, it’s about the Windows password. I was at a loss there :smiley: I have desperately tried to change the password somewhere in MS SQL Server Mng Studio.
Thanks a lot Alexander!
Hi Martin,
No problem, please feel free to contact us on any issues or concerns.
