Cannot schedule more than 3 jobs
I am running v10, with paid Pro license, and I have 5 jobs I need to run.
In the Jobs list, I have 3 jobs with green icons, and they run OK.
The other jobs have a grey ‘gear’ icon, and they do not run un-attended.
Help please
Hello William_Edgar,
The version you use is very old and no longer supported. We recommend you to upgrade to the latest release - version 12.3.11 https://sqlbackupandftp.com/download and check if it works for you.
If you get any issues with SQLBackupAndFTP version 12.3.11 please send us a screenshot of the issue.
