Bug? -> Connection to ftp didn't work
I try to test the software, but an error occured. Bug?
(with WINSCP i can connect without problems)
Hello Pascal,
Could you please check the following:
  1. Is the host address is specified correctly?
  2. Check the Advanced Options and Even More FTP Settings to make sure they match your FTP Server.
  3. For the correct work with FTP, we use Rebex libraries. Could you please try to install the following test Rebex client Dropbox - RebexFtpClient.zip - Simplify your life and check if you are able to connect and download a file to your FTP via RebexFtpClient?
