Backup postgres only on specific schema
Hello, I’d like to backup a single postgres schema for selected database.
Using a custom script it could be the solution? Or something else?
Thanks!
Hi Antonio,
Sure you can do it, the option to backup only schema can be found at the “PostgreSQL Backup Option”.
