Is it better to have ‘Checksum’ and ‘Verify After Backup’ checked or unchecked? They were not checked by default. I am compressing while backing up and sending zip files to Backblaze. Should these options be checked.
Great program - thank you!!
Hi Ron_K,
Thank you for the warm words.
It’s up to you, to keep enabled or disabled these options. We just recommend you to check the following bog posts:
If there is anything else we can help you with, please let us know.
