Backup MSSQL 2022 Eval on MinIO
Hi there,
This is what I have:
  • I installed Windows 10 and on it I installed MSSQL 2022 Eval
  • In installed Ubuntu 22.04 and on it I installed MinIO latest [via Docker]
What I’mm trying to do:
  • Backup MSSQL 2022 from Windows machine to MinIO from Ubuntu machine
What I did:
  • MinIO is over https [self sign certificates as both machines are locally, virtualized]
Run these commands for Backup [NOTE: the commands are run from a sql docker container from Ubuntu machine]:
1.
QUERY=$(echo "CREATE CREDENTIAL [s3://10.5.5.10:9000/sql] WITH IDENTITY = 'S3 Access Key', SECRET = 'user:pass';")
sqlcmd -S 10.5.5.11,1433 -U sa -Q "$QUERY" -P 'S0methingS@Str0ng!'
QUERY=$(echo "BACKUP DATABASE DBTest TO URL = 's3://10.5.5.10:9000/sql/DBTest.bak' WITH COMPRESSION, STATS = 10, FORMAT, INIT;")
sqlcmd -S localhost,1433 -U sa -Q $QUERY -P 'S0methingS@Str0ng!'
The error that I’m receiving is this:
Cannot open backup device 's3://10.5.5.10:9000/sql/DBTest.bak'. Operating system error 12175(failed to retrieve text for this error. Reason: 317).
Msg 3013, Level 16, State 1, Server DESKTOP-5CSDK6A, Line 1
BACKUP DATABASE is terminating abnormally.
Hello Astin,
We apologize, but it appears that the issue is not related to our application, and unfortunately, we don’t have any suggestions to offer in this case.
If you encounter any problems specifically related to SQLBackupAndFTP, please feel free to inform us.
Thank you, and we apologize for any inconvenience caused.
