Backup files not found when restore from Azure Storage
I backup mysql and store in Azure storage successful, but restore job cannot found any backup files.
Error: Backup files not found. Please make sure if you have a configured backup job with the specified destination.
Check where is the destination of the backup files, then click the icon on the right to browse the location, and the file you want to restore.
Hi Jorge_Alexandres,
Thank you for your suggestion, yes, it should help.
Thanks for your reply.
I confirm that the backup files exists in Azure storage, but it’s still nothing in step “select databases to restore”. I want to restore database to another server.
Where is the icon you said?
Hello guys,
We have checked the issue and it seems the issue is on our side. Please give us some time to fix it.
For now, as a workaround, please specify a path to a folder in your container at the “Advanced Azure Storage settings”.
Yes, it’s working, thanks for your help.
Hi Zeno,
Thank you for your reply.
Hello guys,
The issue has been fixed in the latest release of SQLBackupAndFTP version 12.6.9. Please make sure you use that version and check if it works for you.
