Backup Failing - connection forcibly closed
Trying to backup an SQL db to Wasabi and getting the following error (log attached)
24/09/2021 12:42:36 [Error] Destination error: Failed to upload “C:\Users\nathaniel.durman\AppData\Local\Temp\Pranas.NET\SQLBackupAndFTP\backup\finishing202109241048.zip” file to “” folder. > One or more errors occurred. > Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. > An existing connection was forcibly closed by the remote host
Thanks,
Hi Nathaniel_Durman,
Could you please check if you are able to connect and upload a file manually via S3 Browser?
