I have a client for which I have installed SQLBACKUPANDFTP. Now they have a second SQL instance in their office. Can the software backup databases from both instances on a schedule?
Marios
Marios
Hi Marios,
If you can connect from one server to both your DBMS, then yes, you can backup the databases from both instances.
