I’m trying your software for a MySQL application, but when I restore the database, it doesn’t work properly.
By the application itself, the following sequence makes the backup valid:
%mysqldump% --routines --host=“localhost” --user=%dbUser% --password=%dbPassword% DORSAL > “%backupDir%%file%”
Is there anything I can do to make the backup look identical? (manual and via sqlbackupandftp)
