Until the upgrade to version 12.7.x, I had been creating backups and restores of database connecting to mysql servers in RDS via TCP. There was a specific command
--set-gtid-purged=OFF
that had to be set in “More settings” section. Failure to do this would result in the following error:
Error Code: 1227 Access denied; you need (at least one of) the SUPER privilege(s) for this operation
After the upgrade the 12.7.x, it started giving me the above error even though none of the settings had changed and they were exactly the same.
This is how my settings looked like:
I also followed AWS’ advice in the following link, but considering I have no functions nor events or anything it wasn´t an issue. It continued to fail for me regardless of updating parameter groups, changing databases etc.
What DID work for me is the downgrade to 12.6.9 of SqlBackupAndFTP, and it was able to restore my backups successfully, so it seems like theres an issue with the upgrade or there are breaking changes that were not contemplated maybe? We use MySql 5.7 in RDS.
Could this please be looked into ASAP as we would like to buy the license for this but this upgrade is stopping us from buying it.
