Auto delete backups after ... not found on the destination
12.3.8. Professional
We have recently rebuilt our Windows Server and upgraded it to 2019. In the process of re-establishing our existing backup jobs we changed the folder destination for the backups Store backups in selected destinations.
The backups work fine. However, the auto delete backups is failing and reporting the old destination (see log snippet below). Is there a file we can edit and then find and replace all occurrences of the old destination with the new destination?
Clive
• 6:30:26 PM : Cleaning up backups of “tbs_dat” database at “Folder” destination “C:\SQLBackupAndFTP~Accounts”
• 6:30:26 PM : D:\SQLBackupAndFTP~Accounts not found on the destination.
• 6:30:27 PM : D:\SQLBackupAndFTP~Accounts not found on the destination.
• 6:30:27 PM : Found “3628” backups of “tbs_dat”. Old backups: “4”
• 6:30:27 PM : Deleting old backup of “tbs_dat”. Backup type: “Diff”. Backup time: “07/18/2019 06:30:00”
• 6:30:27 PM : Deleting old backup of “tbs_dat”. Backup type: “LogTran”. Backup time: “07/18/2019 07:30:00”
• 6:30:27 PM : Deleting old backup of “tbs_dat”. Backup type: “LogTran”. Backup time: “07/18/2019 08:30:00”
• 6:30:27 PM : Deleting old backup of “tbs_dat”. Backup type: “LogTran”. Backup time: “07/18/2019 09:30:00”
Hi Clive,
The information is stored in SQLite database which is located by the following path C:/ProgramData/Pranas.NET/SQLBackupAndFTP/Db/routines.db
The path can be fount at the following “BackupObject” table.
