Application is updating automatically.
in latest version it requires .net 4.6.2
I am using windows server 2008 enterprise service pack 2 and it is not compatible with 4.6.2
is there any solution ??
Right now service is not starting.
If there is no way to install .NET Framework version 4.6.0 or above on your server, then you can download SQLBackupAndFTP for older .NET Framework version 4.0.0. To do it please go at the “Download” https://sqlbackupandftp.com/download page and click “SQLBackupAndFTP for older .NET Framework v4.0.0” link.
Thanks a lot. Older version working proper now. but is there any option to disable auto version update.
Good news! Thanks for the feedback.
Sorry, but currently there is no way to disable auto updates, we plan to add this option.
If you installed SQLBackupAndFTP for .NET Framework version 4.0.0 then your version will not be updated automatically.
