Hi, i want to buy a licence to backup 3 sql databases wich are in 3 different pcs.
Can i use the “lite version” or i need the standard version?
Hello Lautaro_Mendez,
By default, one license of SQLBackupAndFTP can be used to activate a license on one computer. If you can connect from one installation to all your DBMS then yes, you can use a license for one computer. If the license should be installed on each computer, then, please specify the number of computers where the license will be used during the purchase. If you buy a license for at least 2 computers a 15% discount will automatically be applied at checkout (or 20 computers in the case of the “Professional 1 database” edition).
Please find more details at SQLBackupAndFTP Features & version comparison
so can i use the lite version (wich says max 5 databases)?
I need to install the aplication in each one of the 3 pc’s.
Thanks again
Hi Lautaro_Mendez,
To install SQLBackupAndFTP Lite edition on 3 computers, please purchase a license for 3 computers.
SQLBackupAndFTP Lite edition for one computer can be used to backup up to 5 databases from one computer.
