Access temp backup path denied
All setups fine, yet I get the following message: “29.10.2022 09:18:04 [Error] Failed to backup “eazybusiness” database with “Full” backup type: Der Zugriff auf den Pfad “SVWIEV01\099_Sicherung_DB_temp\Pranas.NET\SQLBackupAndFTP\backup” wurde verweigert.”
Hi Stephan Wolfer,
To resolve the issue, please try to specify a temporary folder in your local drive.
Right-click the file or folder, and then click Properties. Click the Security tab. Under Group or user names, click your name to see the permissions that you have. Click Edit, click your name, select the check boxes for the permissions that you must have, and then click OK.
Hi Jameswalter,
Thank you for the details!
