7zip vs 7zip engine compression issue
Got an error while trying to backup a SQL AWS RDS database and it threw an error while trying to compress it , it said “System error - Not implemented” - This happened when i chose the option “7zip (engine)”
8:30:01 PM : ERROR: Failed to backup “TestDB” database with “Full” backup type: 7-zip archiver error. > System ERROR: Not implemented
What is the different between “7-zip (engine)” v.s. regular “7-zip” ?
If “7-zip(engine)” is non-working when choosing AWS RDS SQL backups - then why is it there for selection - shouldn’t it be grayed out or not option when AWS RDS backup is chosen??
Note: it worked correctly when i chose the regular “7-zip” compression.
Hi Luis,
Please give us some time to check the issue, we’ll keep you updated.
Hi Luis,
To investigate this case we need more details. Could you please provide us with the Advanced Log How to send Log to developers – SQLBackupAndFTP's blog
Once the log will be sent, please notify us and provide us with your App ID (“Help” > “About”).
This was taken care of.
I mistakenly added a command that was meant for 7zip and not for zip.
error went away after removing the command in the additional options.
Hi Luis,
Good news! Thank you for the update.
