Does SqlBackupAnsFtp fully supports mariaDB11 backups?
Do I have to set a custom mysqldump, or…?
Alex
Alex
Yes, SqlBackupAndFtp fully supports MariaDB 11 backups.
Just use the MySQL connection type — no custom mysqldump is required.
Docs: https://sqlbackupandftp.com/docs/docs/job-settings/backup-job/connection-settings/mysql/
If you face any compatibility issues, simply specify the path to your MySQL/MariaDB bin folder in the Advanced connection settings.
