X86 12.2.3 version fail on connection
I downloaded the application and it doesn’t connect because isn’t compatible, unless the error message say that.
What can I do?
Hi Hector,
Could you please clarify what databases are you going to backup? If it’s PostgreSQL or MySQL Server databases then please specify a path to your pg_dump or mysqldump tool at your “Connect to Server” window.
I’m trying to connect to a SQL server, this DB isn’t local. Image attached.
Hi Hector,
Could you please clarify have you tried to specify a path to your mysqldump tool as we suggested in the previous message?
I specify a path and finally work.
Thank you so much :slight_smile:
