I’m setting up SQLBackupAndFTP on a remote server. The SQL connection to the database server tests OK. The connection to the NAS that I want to back up to also tests OK - the “open folder” link in the application window shows the correct location.
When I run a test of the backup, every object fails with an error showing that the app is trying to save to a local directory on the database server instead of to the NAS. A copy of the log is below. This is a clean install on a server on the same LAN.
Any idea what could be the problem?
1/9/2018 12:04 PM Starting job “sql_backup.jobx” with backup type “Full”. The computer name: “MEHANDI-TERM01”. The application version: “11.1.22”
1/9/2018 12:04 PM The backup folder of the job is “d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup” with “” free space. The temporary folder of the job is “C:\Users\administrator.WAREHOUSE\AppData\Local\Temp\Pranas.NET\SQLBackupAndFTP\backup” with “759.461GB” free space
1/9/2018 12:04 PM Backing up “192.168.1.209\acctivate” SQL Server databases
1/9/2018 12:04 PM Getting maximum file size…
1/9/2018 12:04 PM The maximum file size: “”
1/9/2018 12:04 PM Failed to backup “master” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Failed to backup “model” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Failed to backup “msdb” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Failed to backup “ACCTivate$TDLFORTIM” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Failed to backup “ACCTivate” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Failed to backup “ACCTivate$TDLNEW” database with “Full” backup type: One or more errors occurred. > Could not find a part of the path ‘d:\ACCTivate\Database\MSSQL10_50.ACCTIVATE\MSSQL\Backup’.
1/9/2018 12:04 PM Cleaning up backups of “sql_backup.jobx” job
1/9/2018 12:04 PM Job “sql_backup.jobx” finished with “6” errors
1/9/2018 12:04 PM Can’t send email to streetleveltech@earthlink.net: Incorrect authentication data (535).
