Upload slow to dropbox why?
MY INTERNET IS 240MBPS
BUT MY UPLOAD FOR DROPBOX IS SLOW … WHY?
GESTOR.jobx has been backed up successfuly
Summary (Success)
Job: GESTOR.jobx
Computer: XXXDNN3671
Date: 10/12/2017 11:55:01 PM
Backup type: Full
Backup archive size: 4.5GB
Database count: 2
Campanhas Full backup: Dropbox - success
Postall Full backup: Dropbox - success
Next backup: 13/10/2017 23:55:00 - Full
Detailed Log:
• 11:55:01 PM : WARNING: Your Professional Trial license expires in 2 day and will be converted to Free automatically. Purchase a license to continue with your backups uninterrupted.
• 11:55:02 PM : Starting scheduled job “GESTOR.jobx” with backup type “Full”. The computer name: “XXXDNN3671”. The application version: “11.2.1”
• 11:55:02 PM : The backup folder of the job is “F:\Temp\Pranas.NET\SQLBackupAndFTP\backup” with “82,502GB” free space. The temporary folder of the job is “F:\Temp\Pranas.NET\SQLBackupAndFTP\backup” with “82,502GB” free space
• 11:55:02 PM : Backing up “.” SQL Server databases
• 11:55:02 PM : Getting maximum file size…
• 11:55:02 PM : The maximum file size: “10,000GB”
• 11:55:02 PM : Backing up “Campanhas” database to .bak file. Backup type: “Full”. Checksum: “Disabled”
• 11:55:04 PM : “Campanhas” database backup successfully completed. Backup type: “Full”
• 11:55:04 PM : Database “Campanhas” has been successfully backed up to “Campanhas201710122355.bak : 1,409GB”
• 11:55:04 PM : Compressing “Campanhas201710122355.bak” file with Internal archiver. Encryption: “Off”
• 11:56:09 PM : Backup of “Campanhas” has been successfully compressed to “(Campanhas201710122355.zip : 237,656MB)”
• 11:56:09 PM : Backing up “Postall” database to .bak file. Backup type: “Full”. Checksum: “Disabled”
• 12:02:26 AM : “Postall” database backup successfully completed. Backup type: “Full”
• 12:02:26 AM : Database “Postall” has been successfully backed up to “Postall201710122356.bak : 41,032GB”
• 12:02:26 AM : Compressing “Postall201710122356.bak” file with Internal archiver. Encryption: “Off”
• 12:33:22 AM : Backup of “Postall” has been successfully compressed to “(Postall201710122356.zip : 4,224GB)”
• 12:33:27 AM : Connecting to Dropbox destination “Postall Transportes”
• 12:33:28 AM : Sending backup of “Campanhas” to Dropbox destination “Postall Transportes”
• 12:33:28 AM : Uploading the local file “Campanhas201710122355.zip” into a remote file “Campanhas201710122355.zip”
• 12:34:54 AM : Uploaded 100 % (average speed = 3,9 MB/s)
• 1:14:50 AM : Verifying remote file “campanhas201710122355.zip” with local one “Campanhas201710122355.zip”
• 1:14:50 AM : Disconnecting from Dropbox destination “Postall Transportes”
• 1:14:50 AM : Connecting to Dropbox destination “Postall Transportes”
• 1:14:51 AM : Sending backup of “Postall” to Dropbox destination “Postall Transportes”
• 1:14:52 AM : Uploading the local file “Postall201710122356.zip” into a remote file “Postall201710122356.zip”
• 1:16:16 AM : Uploaded 100 % (average speed = 84,1 MB/s)
• 1:20:18 PM : Verifying remote file “postall201710122356.zip” with local one “Postall201710122356.zip”
• 1:20:18 PM : Disconnecting from Dropbox destination “Postall Transportes”
• 1:20:18 PM : Cleaning up backups of “GESTOR.jobx” job
• 1:20:20 PM : Cleaning up backups of “Campanhas” database at Dropbox destination “Postall Transportes”
• 1:20:20 PM : Cleaning up backups of “Postall” database at Dropbox destination “Postall Transportes”
• 1:20:20 PM : Job “GESTOR.jobx” finished
Thank you for the issue reporting. To investigate this case we need more details, could you please send us the Advanced Log? You can find a short tutorial on how to do it at https://sqlbackupandftp.com/blog/how-to-send-log-to-developers
Also, could you please tell us, what is the speed when you upload files manually to dropbox?
Good Morning.
IN 1 HOUR SOURCE FILE MANUALLY. NO PROBLEMS. ONLY BY SQLBACKUP DELAY.
Thank you for the details. It seems that we display wrong upload speed. We’ll fix this issue as soon as we can.
Boa noite,
estou tendo o mesmo problema, meu uploading para o dropbox esta marcando 94kbps, levando quase 14 horas pra realizar o backup.
quando eu faço manualmente direto para o dropbox, leva aproximadamente 3h.
helpme, please…
my backup for dropbox is very slow… 94kbps…
my internet link is 5mbps full…
Sim, o meu problema ainda persiste. Tenho 240MPBS mas o upload não passa de 97KBPS. I NEED HELP help desk,
Thank you for the issue reporting. We are working to fix it. Sorry for the inconvenience.
It seems the issue is on Dropbox side. We have contacted Dropbox’s support team to investigate this case.
Hy Alexander.
We need a solution for this case.Can you help me ? The company Dropbox has already taken a position?
Thanks,
Yes, we have received a reply from Dropbox. Please find more details at https://www.dropboxforum.com/t5/API-support/Official-Dropbox-Net-v2-SDK-slow-uploading-speed-for-large-files/td-p/253124
Cool, but what do we need to do to solve the problem? we wait ?
Thanks Alexander. By Guilherme RIbeiro
Sorry, but this issue is on Dropbox side.
Dropbox’s support team says that the connection speed will vary from place to place. Your connection speed to Dropbox depends on the routing you get between your ISP and Dropbox’s servers, and may be slower than your ISP’s rated speeds.
Sometimes resetting or retrying your connection gets you a different route and better speeds, but that is outside of our and Dropbox’s control. Some ISPs also throttle sustained connections so if you see an initial high connection speed followed by lower speeds, that could be the reason.
Also, we can recommend you to contact Dropbox’s support team to check the issue related to your routing.
Hy, alexander.
I’m sorry but before upgrading to this new version always worked perfectly.
So much so that for our FTP it sends in less than 30 minutes, only for the dropbox that takes almost 12 hours.
