Running 11.1.9 and when you go into select a database the first _ is not displayed in the name. It is on the main screen though. See the following image
Could you please make sure that these databases haven’t been deleted?
Yes i can definitely confirm they have not been deleted
Could you please run the following query SELECT name FROM sys.databases
via SQL Server Management Studio and check if you can find all your databases there?
Apologies I have been out of the office. Below are a couple of examples from the select statement
As you can see they have the underscores.
Thank you for the details, please give us some time to check it.
