SQLBackupAndFTP can't connect
SQLBackupAndFTP 12.2.9(Free version) can’t connect. how to fix it
Thanks,
1
Hi Suthep,
Could you please click on the “info” button at the “Connect to Server” window then copy the command and execute it via the Command Prompt to check if you get an error message?
