SQL Backup - Leave recent on SQL server?
I’m currently backing everything up to Google Drive. How can I configure the backup to leave the most recent backup file on the local file system as well? I’d like this so I can quickly access if needed. Currently, SQLBackupAndFTP deletes everything local.
Using version 10.2.13 Standard
SQLBackupAndFTP version 10 is an old version and it’s no longer supported. We recommend you upgrade your current version to version 11.4.4 and use “Auto delete” option to manage your backups.
To upgrade your version please go to your “My Account” SQLBackupAndFTP page and click the “Upgrade” link.
