Problem with backup folders
when I enable the “BACKUP FOLDERS” function I get a credential error on the backup path. in fact the program does not know the credentials of the nas in which I want to save a copy of the backup 05/25/2021 09:52:17 [Error] Failed to backup “SQL” folder in “\ Qnas \ SSCM \ SQL”. Incorrect username or password. how can I do?
Hi ignazio_aru,
With SQLBackupAndFTP you can backup only local files and folders. It seems you try to backup your shared folder, that option isn’t supported, but you can try to specify your user name with the domain at the “User account” window, perhaps that resolves the issue.
