OneDrive not supported api
#1
Backup to One Drive not work, need new API microsoft Graph. Please fix.
#2
Hi Pawel_Mikolajczyk,
Could you please try to reauthorize to your OneDrive, it should resolve the issue.
#3
I can confirm that reauthorizing the application solves the onedrive issue!
Thanks.
#4
Good news! Thanks for the reply.
#5
Hi!
I have reauthorized onedrive, but issue persist.
App version: 10.2.9.23206
I would appreciate your help.
Thanks!
#6
Hi Marin_Kraljevic,
SQLBackupAndFTP version: 10.2.9 is very old and no longer supported. Could you please install SQLBackupAndFTP version: 12.1.3 and check if the issue is resolved? You can download it at https://sqlbackupandftp.com/download
