Mysql conections problem
2019-07-05_141745
I think it just happened with the last update :frowning:
Hi Jose_Manuel,
To investigate this case we need more details. Could you please click on the “info” button at the “Connect to Server” window then copy the command and execute it via the Command Prompt to check if you get an error message?
After reinstalling MariaDB the problem was solved.
Hi Jose_Manuel,
