How to create file in .bak format?
Created the file in .sql format, how to create it in .bak format?
Hi Carlos,
SQLBackupAndFTP uses Standard T-SQL Commands to backups SQL Server databases. To create SQL Server databases backups in .bak format please install SQLBackupAndFTP on the same computer where SQL Server is installed.
SQLBackupAndFTP creates the file in .sql format when you backup Remote SQL Server databases. Please find more details at https://sqlbackupandftp.com/blog/remote-sql-server-backups-explained
Thank you very much!!!
No problem. Please feel free to contact us on any issues or concerns.
