I got following error on an Backuptask - another task on same Azure Server working well…
ERROR: Failed to backup “xxx” database with “Full” backup type: Could not extract package from specified database. > Database ‘xxx_SQLBackupAndFTP_Snapshot’ on server ‘xx’ is not currently available. Please retry the connection later. If the problem persists, contact customer support, and provide them the session tracing ID of ‘xxx’.
Hi Bjoern_David,
Could you please save the following Timeouts.xml file Dropbox - Timeouts.xml - Simplify your life and increase the value in the CloudSql ->Short section? Please find more details about the Timeouts.xml file at How to increase timeout values | SQLBackupAndFTP's blog
Note, SQLBackupAndFTP (Database backup) Window Service should be restarted after adding any changes to the Timeouts.xml file.
