I have had the standard “SQL BACKUP AND FTP” product for two months.
Cannot use my login for a direct mail because the software license on my workstation was purchased by my manager and I do not know how to integrate it into my user interface. How can I get “Support for users with active subscriptions”?
I am using the software to back up the PostgreSQL databases generated to use my Resolve software. Currently worry-free work on the x workstations, no problem with ping and accessing databases. Only
SQL BACKUP AND FTP does not work and since yesterday sent me the error :
Failed to backup “tests2021” database with “Full” backup type: C:\Program Files (x86)\SQLBackupAndFTP\DBMS\PostgreSql\pg_dump.exe process has finished with “1” code. The error message: “pg_dump: error: could not open output file” C:\Windows\Temp\System\Pranas.NET\SBF\backup\ test2021.sql": No such file or directury".
Do you know how can I fix this problem?
Michael
