Failed to restore database on “Restoring” step. > mysql: [Warning] Using a password on the command line interface can be insecure.ERROR at line 107: Unknown command ‘’’.
Hi hanjie,
You get this issue on the string number 107 in the file you try to restore. Could you please open that backup file and check that string? Also please check strings before and after that string.
