Cleaning up backups tipe s3 compatible it is very slow
When the backup process finishes, the SqlBackupandftp tool performs a process called Cleaning on S3 compatible, this sometimes takes many times. I need you not to do this task, what should I do?
Hi Sistemas_de_Informa1,
You can set the “Auto delete” option to “0” months “0” days. Then your old backups will not be removed automatically.
