firstly I get this on startup:-
then it doesnt backup remote files…but it works ok locally.
I cant add a 2nd picture because forum wont let me ! So 1 problem at a time I guess.
Matthew
Matthew
Hi Matthew,
Could you please download SQLBackupAndFTP by this link https://www.dropbox.com/s/6rh22k9jvrtfjt9/SQLBackupAndFTPSetup.exe?dl=0 Then install it and check if it resolves the issue?
Please find more details on how to backup remote SQL Server database using SQLBackupAndFTP at https://sqlbackupandftp.com/blog/how-to-backup-remote-sql-server-database
