Backup fail with Operating System Error 3
Started Full backup and get this error: Failed to backup “Db_V11” database with “Full” backup type: Cannot open backup device ‘C:\Temp\Pranas.NET\SQLBackupAndFTP\backup\Db_V11201711031531.bak’. Operating system error 3(The system cannot find the path specified.)
I do not know what file is required at the mentioned location: the database is located at a remote machine (hosted by my web host provider) and NOT a local SQL Server instance. All Db connection credentials are fine, connection test succeeds.
Within the full log of your backup tool I find something like this:
2017-11-03 14:33:27.7784|TRACE|43|Pranas.NET.SqlBak.Job.Sql.Business.SqlServerHelper|ReadSettingsValue|System.Data.SqlClient.SqlException (0x80131904): You do not have permission to use the bulk load statement.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteScalar()
at Pranas.NET.SqlBak.Job.Sql.Business.SqlServerHelper.ReadSettingsValue(DatabaseConnectionInfo connectionInfo, SettingsNode node, String key, String defValue)
ClientConnectionId:f3aeea52-9754-406d-8322-b10868ad44a9
Error Number:4834,State:1,Class:16
But with an older version of the tool it worked without that permission.
Anyone can help, please?
Please grant LOCAL SYSTEM (or LOCAL SERVICE) account with write/read permissions for C:\Windows\TEMP… folder or specify different temporary folder
Also, please make sure that you have enough free space on your drive.
You can find more details at the following blog post: https://sqlbackupandftp.com/blog/how-to-solve-operating-system-error-3
That does NOT help. And: the remote SQL server is at the hosting provider Site within whatever AD Domain: I cannot establish any trust relationship.
Sorry, but SQLBackupAndFTP cannot perform remote backups. Please install SQLBackupAndFTP on the same computer where SQL Server is installed.
Remote backup is rolling out automatically in SQLBackupAndFTP version 11.4.2. If you don’t have it updated yet, just wait a day or two. To do a remote backup, on “Connect” window select “Remote SQL Server” in “Server Type” field.
