Backing up "127.0.0.1" databases with "mysqldump.exe: Ver 10.9 Distrib 4.1.22, for Win32 (ia32)"
I get error when run MYSQL Backup script
Software Version is 12.4.16 (Lite)
18/3/2564 1:27:27 [Error] Failed to backup “xxxx” database with “Full” backup type: mysqldump: unknown option ‘–routines’
Has anyone found this problem before?
Please give us some time to check the issue. We’ll keep you updated.
Hi sitstandard,
Sorry for the delay.
Could you please go to the “MySQL Backup Options” section and disable/enable the “Add CREATE PROCEDURE/FUNCTION” option.
Also, please try to specify the path to your mysqldump at the advanced connection settings. Make sure you use version 5.1.30 or higher.
Thank you this issue has beed solved
